In All Her Glory!She’s back…!
I am getting an error code. The exclamation, I can’t sort out what it is even with the OBStarIn All Her Glory!
Congratulation Apuca, this once again proved that whenever there is a will, there is a way
Hi Apuca,I am getting an error code. The exclamation, I can’t sort out what it is even with the OBStar
I did. I needed to replace the rear wheel speed sensor which was damaged during the crash. I just checked the wheel sensor gap, should be btw 1.3-1.8mm and it falls at 1.380- so all good. I carefully made sure all connections were in place and nothing was loose. I also swapped out spark plugs (all gapped properly) and the bike runs smoothly. I have not ridden it yet as I’m missing a seat I’m still waiting for. The other option is to connect and reconnect some wires or the dreaded Ducati service.Hi Apuca,
Did you remove any wiring during the re-build? Maybe just a loose connector.
Or, perhaps some cable was either pulled or torn during the fall?
I checked both O2 sensors both Connections and torque on headers. I’m wondering if the code is just still there from the crash. Still, it’s not mechanical so it should be fixed with replaced wiring.Hi Apuca,
Test wheel speed sensor errorWhat code is it?
I haven’t ridden the bike yet. I’m assuming that would be with the OBStar device?Test wheel speed sensor error
Yes so when I spin the rear wheel on the stand you do get 1-2mph read on the dash.Are the sensors detecting the wheel speed? You should be able to see that in the ECU or BBS page.
