Carbon fiber frame can be repair, 3 links below:Frames are cracked. Rear wheel shattered.
McLaren 600LT Carbon Fibre Repair
McLaren Chassis Repair - Carbon Fibre Repair
mclaren carbon fiber repair - Google Search
That would do it.Frames are cracked. Rear wheel shattered.
Depends, It may be salvageable.That would do it.
There looks like there's salvageable parts. Are you going to part it out or just take the payout?
I am going to rebuild it myself. I was able to find a middle ground with Insurance.Can't you refit your original frame for now. Wheels are easily replaced. As others have said, I've seen a lot worse come back from the dead and hit the road/track again. One guy in the UK had the rear swing arm completely ripped off his V4S. Had his frame and essential geometry checked on a jig and all OK, so he simply sourced another swingarm. Your bike might not look pretty right now but there is not much that cannot be fixed, unless it's bent up beyond recognition, which does not appear to be the case judging from your photos.
