Ok, so first, I applied the Loctite 222MS on the ProTi Titanium Bolt that hold the hose to the engine crankcase and tightened it to 10Nm:
Then I tightened the hose end going to the oil cooler with a special set of open ended wrench and torque wrench to 15Nm (setting the compensation for the extra length in my Snap-On torque wrench offset system of course):
Then I also "spaced" the 2 hoses using the Setrab Billet Aluminum Hose Separator and also using that longer non-metric hex socket bolt:
And here how they looks like installed:
Now time to fill back the oil I had been draining a few months ago:
Then I started the engine... wow... I missed the sound of this engine... so angry yet melodious :love:
I then checked to make sure no oil leak and everything is good.
Now, I remember a few months ago, @bp_SFV4 was reminding me that my Rizoma turn signal located near the edge of the Termignoni silencers could be damaged from the hot exhaust gas.
I finally had a chance to test this by turning on the engines for around 5 minutes and bp_SFV4 is correct that it will be too hot for those Rizoma turn signal (at least will mare the anodized surface of it).
It was ok today, but I would like to make sure if someday I turn on the engine for a lot longer time (or riding it someday 😃) it will be ok.
So I am going to purchase the super short Rizoma mounting adapter FR440B made of Polymer and will ceramic coated it for further protection from heat.
Note that I don't need to use the extension tube and only need to use that "L" shaped housing so it will be super short:
and then use it with my Rizoma FR070BM that I already have (originally bought for the front turn signal) to test fit and make sure it is far enough from the exhaust gas flow.
If everything is good, then I just going to buy another FR070BM for the front turn signal.
Here are the comparison:
Too bad, I really love the Red Rizoma Corsa Turn Signal shape and color... but like anything in life, things does not work they way you want it to 😌
Of course, it this still doesn't work there are always other solutions... I just too lazy (and to busy at work) to design another custom machined bracket for now 😇
Pete T
Moderator
Elegant solution for the tail, bringing together quality components that look right as a unit.
I like the clamp that keeps the coolant hoses in place but it really needs a grommet around the hoses as vibration will quickly mark and could ultimately wreck the braiding.
Great innovation as always H.
Thanks so much for the suggestion Pete, I will look into some kind of grommet like you suggested above. (y) 😃
I like the new turn signals. The exhaust gas has so much velocity especially at high revs that it should easily clear the new ones before dispersing.
I decided to start the engine of my bike again for a few minutes to enjoy the sound, but this time I sat on the bike while turning it on...
and.... woaaaa... the heat coming out from the right rear manifold was very strong... no wonder many people complain about the heat burning their right leg...
I think I need to find a way to cover this exposed exhaust manifold pipe somehow:
I was excited and thinking on applying the research for the fuel line I just finished for my 998 and thinking of applying this AN plumbing upgrade to the V4... (well at least from the fuel tank to the T junction going to upper and lower injectors) 😅
Here is the link to my post about it:
https://ducatimodified.com/threads/ducati-998s-fe-final-edition-replica-but-modified-far-beyond-the-original-build-thread.148/page-10#post-5059
But just realized Our V4 has super tight space and the fuel hose out of the fuel pump is super short (and it's use barb) so it will be harder to use the Staubli's... I mean everything is possible but I just feel that is not worth it unless I can replace everything with AN plumbing (without having the do custom welding on the fuel pump bracket)...
Here is the picture from spare part catalog and the super short hose #11 in the picture below is what I was thinking to be replaced with a dry break AN system... but again the barb connector out of the fuel pump is the deal breaker for me...
Bruce Wayne
I used the quick disconnect from the GS BMW i will take a picture of the fittings tomorrow and post them. Im going to modify this again to make it neater i will keep you posted
Max
Bmw alpina when you bought your cordona quick shifter did they send you the longer rod for the Ducati by performance rearsets? Idk l if the 2021 panigale v4s with Ducati by rizoma rearsets and cordona quickshifter requires the longer rod like the sf?
Hi Max, the rod they send me fit perfectly with my Ducati by Rizoma rearsets. But my bike is a 2020 model.
  • Like
Reactions: Max
Hello Max,
The total length is around 21 to 22cm from center of the bearing joint to center of the other bearing joint, picture below:
