Howard, nice touch with the Ducati performance sticker. Where did you get that?Did a few more things this weekend,
Use the remaining adhesives to lock and secure the mounting tab of the Peter Lieb's lower carbon fiber belly pan to the Ducati lower belly pan fairings (I am talking of the mounting tabs between the bolts/nuts in the pictures below:
View attachment 7148View attachment 7149
Then I test fit this Ducabike ABS/Speed Sensor protector at the front Ohlins mounting location:
View attachment 7150View attachment 7151
Looks great, so I measure the correct length needed for the ProTi bolts for it since the bolts that came with Ducabike kit was just standard stainless steel...
then I decided to test mount with the front mudguard to make sure they fit.. which they did, and kinda hide it but still have that "peek a boo" interesting looks:
View attachment 7153View attachment 7154
Which inspire me to purchase another one in RED Anodized for the Rear ABS/Speed sensor which will be a great match for my red anodized painted billet superleggera rear caliper bracket:
Next, I install some ProTi bolts and Titanium Washer for the Ohlins steering damper to clip-on handlebar.
Left picture is BEFORE (well it already have ProTi bolt but with steel washer) and AFTER (right picture), now with ProTi Titanium Washer plus different shape ProTi bolt:
View attachment 7157View attachment 7158
Last, I am adding the Ducati Performance decal on the Peter Lieb's Carbon Fiber frame cover.
First, I cut the sticker to make it easier for me to align properly:
Peel of the backing paper carefully (need to be careful since those lettering are very fragile and easily stuck to the backing paper):
Then I apply it on the top surface of the Peter Lieb carbon fiber frame cover for a more subtle location:
View attachment 7161View attachment 7162
Then, carefully peel off the top transparent tape so the lettering stay on the Carbon fiber... and voila, PERFECTO:
View attachment 7163View attachment 7164
That is it for this weekend...
Howard did you change your clip ons? i did and my steering dampener is all misaligned now. The one that came with the cnc racing clip ons looks like junk and I do not know if the ducabike will be much better and when I saw you lock yours I was wondering if I could do the same. Is yours the manual or the electronic? I have a 2021 panigale v4 s. Thank you for your help buddyDid a few more things this weekend,
Hello Apuca,Howard, nice touch with the Ducati performance sticker. Where did you get that?
Hello Max,Howard did you change your clip ons? i did and my steering dampener is all misaligned now. The one that came with the cnc racing clip ons looks like junk and I do not know if the ducabike will be much better and when I saw you lock yours I was wondering if I could do the same. Is yours the manual or the electronic? I have a 2021 panigale v4 s. Thank you for your help buddy
Thank you Howard I really appreciate the response like always. True gentleman. Sorry I should have asked on my last post but how was your experience with vulture bike? I’m going back and forth with them and flamingo for a brushed aluminum tank cover and would love an honest opinion and if it was straight forward like Peter lieb.Hello Apuca,
I purchase the Ducati Performance sticker from Ducati Performance stickers' kit 4 pieces
Hello Max,
I did not change my clip on handle bar (yet). This is still the original Ducati handlebar.
Mine is the Electronic Steering Damper from my Ducati Panigale V4 25° Anniversario 916 is mechanically and electronically a V4S.
I think many people successfully used the clip on handle bar from ImA and that is what I plan to use for the upcoming Ohlins FGR400 since the Ohlins FGR400 forks diameter is 54.5mm (our current EC Ohlins forks is only 53mm).
Here is the link to the ImA handlebar: MOD.5 P (Panigale Adjustable Clip ons) - Ima Special Parts
Alternatively, you can also purchase from AELLA (Bellissimoto is their distributor in the USA): セパレートハンドル(Panigale V4) | AELLA オンラインショップ
Thank you so much for your kind words BrooklynV4, I really appreciate itYour attention to detail is fantastic. Subtle things that stand out and look great
Hi Max,Thank you Howard I really appreciate the response like always. True gentleman. Sorry I should have asked on my last post but how was your experience with vulture bike? I’m going back and forth with them and flamingo for a brushed aluminum tank cover and would love an honest opinion and if it was straight forward like Peter lieb.
That’s a better answer than I was expecting as it means I have another source to buy stuff from! Thank you Howard!Thank you so much for your kind words BrooklynV4, I really appreciate it
Hi Max,
I was checking my bookmark and that is how I found out Vuturebike made this sticker... however since you asked my buying experience, I checked my emails with all the receipt and just could not find Vuturebike transaction.
So after more click and search, turn out, I bought this sticker from CarbonWorld.DE in Germany (link below) along with a few other items. CarbonWorld source this sticker from VutureBike (as described on their webpage).
So to answer your question, I did not have direct experience with VutureBike but it was a good experience with CarbonWorld.DE. Having said that, I am sure VutureBike is also a good company to deal with because CarbonWorld.DE willing to represent VutureBike.
Please review the link below:
sticker "Ducati logo performance" for Ducati | Carbonteile und Carbon Zubehör für Ducati Aprillia Suzuki KTM und MV Agusta Sp
Hello Jrkk,Hi Howard.
I'm trying to find that smaller abs pump plastic cover/bracket.
In your post, you refer to superleggera bracket, but it seems that it's still bigger than Akrapovic version.
Did you cut your bracket or what.
This is screen shot from superleggera parts diag. Number is 8291H921A. And by the way, it's same as streetfighter v4.
Akra version doesn't have place for exhaust valve motor. Akra doesn't provide part numbers.
OH, now I understand your point, the part diagram that you show was for the STOCK Superleggera V4 bracket which is basically the same as our regular bracket.Hello Jrkk,
I did not cut or modify anything, it is exactly the Superleggera V4 part.
I am not familiar with the Akrapovic version though...
