Brooklynv4
How difficult is the installation of the samco kit I’m thinking about it for next year possibly. What are the benefits
It’s not super difficult but very tedious. You are taking most of the bike apart. The hoses will help with cooling efficiency and a little bling. Honestly the reason I put them on my bikes is longevity. The silicone hose heat cycles way better than it’s rubber counterpart. So it’s easy to keep clean last longer adds a bit of style. So win win as long as you get the right length hosesHow difficult is the installation of the samco kit I’m thinking about it for next year possibly. What are the benefits
Ok you twisted my arm enough I’ll do it over the winter. My bank account is going to hate me thoughIt’s not super difficult but very tedious. You are taking most of the bike apart. The hoses will help in cooling efficiency and a little bling. Honestly the reason I put them on my bikes is longevity. The silicone hose heat cycles way better than it’s rubber counterpart. So it’s easy to keep clean last longer adds a bit of style. So win win as long as you get the right length hoses
Exactly. I’m sure they are also logging pressure. So much data.To data log lever position?
If you start running sensors all over the bike, you really should step up to an engine management system capable of logging all of them.Exactly. I’m sure they are also logging pressure. So much data.
Don’t judge me but I may buy one for my EVO master.
After I read your post above, I ran to my bike to see if my RCS Corsa Corta MC have provision/thread bolt hole to mount this potentio meter, and I am so glad it did not have any, so I have a "logical" excuse for not buying the potentio meterExactly. I’m sure they are also logging pressure. So much data.
Sundays winning lotto numbers!Any guesses on the significance of those numbers?
Wow, this BUILD just raised the bar at DUCATImodified to Motorsport LevelFront wheel speed sensor project
Here is were we started
Adding a Deutsch ASU autosport connector
These are the same connectors used by all high end motorsport teams in Formula 1 MotoGP and WSBK.
Here are some of the specialty tools needed to install the connector.
Installed
Now we loom. I used a mixture of Raychem DR-25 US and Raychem HFT5000. If you've never used this stuff its incredible chemical abrasion and heat resistant.
Heat resistant up to 302 deg for 1000 hours. Crazy stuff.
I wanted to add my own touch since its my custom part I came up with a part# 32.100.21.11.R
Makes maintenance easier if you needed to remove the front end. They are more durable and lighter than plastic connectors. Last longer in extreme conditions. All great features none of which really apply to me lol. I did it for a couple reasons first it looks cool second I get practice making them for a up coming mod.What’s the advantage of the Deutsch ASU autosport connector?
