That’s what I thought. Subsequent maps are like $150?You get the first map of your choice for free.
Something like that, yeah.That’s what I thought. Subsequent maps are like $150?
Hi MaverickiB,Disaster struck and my V4 decided it no longer liked the OEM plastic thermostat housing. It split, causing one of the hoses to detach, and purged all of the coolant it had into my belly pan. The racing belly pan did its job and kept the majority of it from reaching the track. Was only a few laps in to the first session of the day, and reaching that part takes hours of disassembly, so the day was effectively ruined. The techs there said they have seen that part fail on 4 V4s over the past few weeks, since it is just cheap plastic.
Will be swapping over to this. Recommend it if you track your V4 and don't want to splurge on a completely different radiator setup that bypasses it.
Home :: Parts :: Ducati :: V4 (18-24) :: Radiator :: CBE Ducati V4 Panigale Streetfighter Billet Thermostat Bypass Junction Adapter (2018+)
CNC MANIFOLD – THERMOSTATIC VALVE REMOVER FOR DUCATI PANIGALE V4 ALL M Y Main features Replace OEM part made by plastic that could be subject to breakages Allows the reduction of the working temperature of the engine Material AL 6082 CNC machined from solid on 5 axis machine Plug & play same...www.hsbkracing.com
Can't help but think you should have asked if it comes in gold, haha.Hi MaverickiB,
First, I am glad that your belly pan catch your coolant and you and your bike are ok.
Second, I want to say thank you so much for posting this information. This is great/perfect timing because I haven't assembled my throttle body so I can replace my plastic thermostat housing easily.
I just placed an order at HSBK racing, Thanks again
I was actually thinking to anodized it in gold, but, with the constant heat from the cylinder head and the hot water coolant, i think it will fade the gold anodizing fast so I decided against that,Can't help but think you should have asked if it comes in gold, haha.
Wow, that is very unfortunate,...Forgot to update here. No big changes, just finally got my Sicom rear rotor installed. Ordered it in August of 2020 and recieved it in May of 21. Covid sucks.
Fighting through some fueling issues currently. Not sure why, but Termi bricked my T800 tune. The bike is basically unrideable following a firmware update on the device. Slowly rolling on the gas, RPMs reach 4k or so and then just stop. Continuing to roll the throttle does nothing until a certain amount of degrees, then it surges to 7-8krpm. If you hold the throttle at that point, it will maintain that rpm for a few moments and then die out to barely above idle rpm despite the throttle still being open. I suspected a TPS or MAP issue, but reverting to the OEM tune yields zero issues whatsoever. Throttle and RPM stay perfectly synched and everything runs great despite the multitude of lambda error codes.
Termi has unfortunately abandoned me. They refuse to acknowledge their device could be an issue. I asked if they could replace the map in my account with a different map just for the sake of troubleshooting, to which they responded in the professional equivalent of "fuck you it isn't our fault and that's final."
I'm wary or spending another couple hundred dollars on another one of their tunes only for the problem to persist. I think I'm just gonna settle with OEM until a real tuning solution comes out. I'm hoping what will likely be just a day or two on track with OEM fueling (lean) won't cause any notable damage. I'll definitely have to keep an eye on engine temps.
That Sicom rotor is nice.Forgot to update here. No big changes, just finally got my Sicom rear rotor installed. Ordered it in August of 2020 and recieved it in May of 21. Covid sucks.
what a sexy bro
The disappointing part is the tune has worked perfectly well for me for the first 2 years or so of running it. It has always been buttery smooth, then suddenly went to shit after a forced update. Not sure if they changed the way the dongle communicates with the bike in order to better suit the newer models, but my poor 2018 has been effectively kicked to the curb.@MaverickiB sorry to hear about the issue bro. It’s exactly issues like this that have me hesitant to add an exhaust.
Maybe it’s time to go MoTec?
It’s interesting to me that stand-alone engine management is so common in the automotive aftermarket performance community, but almost nonexistent in the bike community. Anyone have any insight why that is?
Totally agree with you that the cost (and economic of scale) is the main barrier to entry on why stand-alone system is not popular with bike as much as for car... I mean a ratio of a MoTec system you mention above compare to the cost of the Panigale V4 is well almost like buying another bikeThe disappointing part is the tune has worked perfectly well for me for the first 2 years or so of running it. It has always been buttery smooth, then suddenly went to shit after a forced update. Not sure if they changed the way the dongle communicates with the bike in order to better suit the newer models, but my poor 2018 has been effectively kicked to the curb.
MoTec is the dream, but I do not have 20k to spend, lmao. It seems like tuning issues are mostly prevalent with companies that link back to Audi. Talking with a Woolich rep quite a while ago when the V4 first came out, he said the problem they're having is the ECU is setup to detect non-OEM tunes. Even with the UpMap device, if you leave the lambdas connected, they are "disabled" by the device but still residually take measurements and the ECU slowly reverts its way back to OEM. Third party tuners can get a tune in the ECU but cannot get it to remain unmolested.
Super gay. Holding out, been hearing "just a few months now" as the ETA on a real tuning solution for 3 years now.
I think it is "economic of scale", the more unit sold, the less the margin to break even, the lower the cost.I agree cost is the main prohibition. I should have asked - “why is it so expensive?”
MoTec is quite popular in the supra community - you can go MoTec with a motorsport spec custom wiring harness for under $10k.
If they’ll do that, I’m down for a group buy.IIRC, it has to communicate with a proprietary IMU, which requires a proprietary relocation bracket, which requires a battery and electronics cradle, and so on. I might try to contact them and see if they sell a harness/sensors setup compatible with the OEM IMU/BBS/etc.
Edit:
Shot SBU an email about it. Hopefully they respond with good news. A bare bones harness that works with OEM sensors would he a godsend and would likely lead to me going with Motec. I'll also have to check around and make sure someone local can tune with Motec.
