Hi Tsaico, they are 32 and 36mm piston, so you will need RCS19 brake MC (larger than Stylema/GP4-MS Caliper which can use stock MC or RCS17)i know it’s an older post, but, thinking of upgrade. what is the piston size for this ?
Thanks! BMW Alpina! You are life saver! Ok, I might want to get the gp4-ms then….anyway I can source the 30mm titanium drilled piston from brembo?Hi Tsaico, they are 32 and 36mm piston, so you will need RCS19 brake MC (larger than Stylema/GP4-MS Caliper which can use stock MC or RCS17)
Hi Tsaico,Thanks! BMW Alpina! You are life saver! Ok, I might want to get the gp4-ms then….anyway I can source the 30mm titanium drilled piston from brembo?
I am very grateful for this! Should I go to billet master? As I’m upgrading to MS ….Hi Tsaico,
I am not sure if you can source the 30mm Titanium Drilled Piston from Brembo, but you can buy it from Ducati Kaemna in Germany and here is the link: Tuning-Teile kaufen und Tuning Tips | Ducati & Aprilia-Tuning Kämna
I buy my Pistal forged (engine piston) for my Ducati 998 with 999S overbore engine project also from Ducati Kaemna so I can vouch for their good service. What funny was, I also was researching for the titanium drilled piston for my own GP4-MS that I ordered for my 998 project just 2 days ago
You can also buy the stainless steel piston from BrakeTech for the GP4-MS as a lower cost alternative to this Titanium Drilled Piston.
It depend on your budget so the RCS19 Corsa Corta (buy the Corsa Corta version because it is the latest model and not just the RCS19), is a FORGED design then finish with extra machining.I am very grateful for this! Should I go to billet master? As I’m upgrading to MS ….
bought the TiN drilled piston. Interesting enough, other shops in Germany claimed 4 weeks of lead time, so I bought it from Ducati Kaemna. Thanks for the pointer again!Hi Tsaico,
Will the outward pointing bleed nipple be an issue if you fit longer Stahlbus bleeders, as they will be very close to the edge of the brake disc, or could you blank this port off and just use the outer port for both banjo and bleeder?View attachment 10077
New Brembo GP4-LM (Endurance)
Unlike the GP4 Moto-GP and WSBK version,
This GP4-LM will be available for non team / regular customers.
So far the launch date will be around March 2023
WRS.IT already accept order:
XC1AB10+XC1AB11 GP4-LM RADIAL BRAKE CALIPERS BREMBO RACING KIT 108MM MONOBLOCK CNC P4 30/34 ENDURANCE
I think they are still above the edge of the disk brake, so hopefully won’t be an issue.Will the outward pointing bleed nipple be an issue if you fit longer Stahlbus bleeders, as they will be very close to the edge of the brake disc, or could you blank this port off and just use the outer port for both banjo and bleeder?
Every braking parts in this video looks prohibitively expensiveStumbled across this quick clip today of the race team putting it all together. Thought you guys/gals might like it too.
Details | We ❤️ details. And you? | By Aruba.it Racing - DucatiFacebook
We ❤️ details. And you?www.facebook.com
Very coolStumbled across this quick clip today of the race team putting it all together. Thought you guys/gals might like it too.
