So with all the wiring complete inside the undertray, the next headache was shoehorning in all the wiring in the tail compartment for the GPS, DDA and then routeing the separate loom section for the rear number plate light and indicators, as well as the Optimate charging lead. The loom splits again at the rear, to the rear light and diagnostics port, so those need to be routed under the undertail closing panel and are relatively easy to accommodate in the space available, as these are located outside the tail compartment.
Here's the undertray wiring completed. The loose connector goes to the fuel tank pump when fitted. I added spiral wrap to the DES wiring, so that it cannot fret against the carbon aperture in the undertray potentially damaging the wiring.
I might change out the spiral wrap for a black version before I call it done and fit the fuel tank, so that it is not so "in your face".
