LATE last weekend update
I continue tie locking and rubber banding all the wiring on the right side of the bike, including securing the ByPass Plug for the exhaust servo:
Then, I secure the rear ABS/speed sensor cable, the rear brake light switch cable together with the solid cooper brake line with the modified carbon fiber brake reservoir holder (notice on the right picture, the small black clip that hold the rear ABS/speed sensor wire, clip perfectly (in size) with the cooper solid brake line):
The connector for the brake rear light switch also clipped perfectly with the carbon fiber bracket, I also follow the service manual on the location of all tie-lock and rubber band (and it some cases add more rubber bands or tie-lock):
Next is to reuse the factory head shield but I rolled it tighter since now it only protect the rear ABS/speed sensor cable (while before it also protect the stock factory hose). It is kinda loose, so I decided to add some glue while rolling it as tight as I can then tie-lock them in 3 locations:
By the way, the Goodridge Aramid braided hose is now protected separately with the Goodridge heat shielding (you can see on the picture below, at the left upper corner of the picture):
You can also see below in the picture both the rear ABS/speed sensor heat shield side by side with the Goodridge heatshield:
Now, I was worried that there is any gap that will expose the rear ABS/speed sensor wire to the very high heat from the SC-Project WSBK pipe only 3/4 inches away, so I push the heat shielding as far into the plastic bracket that hold all of this to the swing arm, making sure no surface of the ABS/speed sensor wire were exposed, and you can see on the picture below.
The heat shield is side by side without any free space with the black plastic bracket. (by the way, I can't find anyone make a carbon fiber version of this plastic bracket while the 1299 had some carbon fiber version, so hopefully someone make a carbon fiber version in the future, it will looks nice):
Then I continue running the rear ABS/speed sensor further toward the rear and secure them using the 4 black clip that again clicked perfectly to the solid cooper tube:
I then take a break from the rear brake hose/wire setup to review the rear carbon fiber Ducati Performance mudguard for the Akrapovic Full System exhaust and try to figure out which section I need to cut to clear the piping of the SC-Project WSBK exhaust.
I think, I can get away with cutting that trapezoid marked in black sharpie, but if I can't, then I will have to cut more. This is next weekend project
Back to rear brake setup...
I remove the rear set again, clean the SC-Project WSBK exhaust pipe surrounding it with Alcohol (since I am sure there are a lot of my finger prints there while trying to route the rear ABS/speed sensor), to avoid from my finger prints being permanently etch the first time I start the bike with this exhaust.
Once everything is clean, I install the Carbon Fiber heat shield and tightened all those small ProTi bolts to around 4Nm, slightly lower than the recommended 5Nm because I feel 4Nm is already tight enough and don't want to risk cracking those carbon fiber., hopefully everything is done on this area so I don't have to took them out again.
I also tightened the right rear sets bolts to 25Nm since I believe, everything is done in this area and no need to took out the right rear set again (hopefully I am right
Then I tightened the Stahlbus Banjo/Bleeder bolts onto the Brembo Billet rear master cylinder to 23nm also making sure the banjo angled at between 4 to 5 o'clock so it provide good clearance from the exposed exhaust manifold while not pulling or pushing the rest of the hose:
Next is to install the Ducati by Rizoma brake reservoir with the longer M8L45 (45mm in length) ProTi Titanium bolt holding the Rizoma rear view mirror bracket that I improvised to hold the reservoir. I tightened the bolt to 10Nm adding Loctite to make sure it won't move despite vibration from engine).
Also, please note that this Ducati by Rizoma brake reservoir is originally for the FRONT Clutch brake reservoir because the Ducati by Rizoma brake reservoir for the rear master cylinder does not come in this kind of slanted glass styling.
I also spaced it well to make sure I can open/close the cap without scratching the Motocorse tripod engine frame holder:
Now, it's time to connect the rubber hose from the Ducati by Rizoma reservoir to the Brembo Billet Rear MC.
All Brembo Billet Rear MC originally designed without any external rear brake reservoir, but I always prefer the "conventional and nostalgic looks" of a brake reservoir.
That is why I choose this model, eventhough it is more expensive than the other model because it have that top bolts that I always suspect can be use for rear brake reservoir.
I found a nipple with thread that fit perfectly but the nipple is smaller in size than the regular brake reservoir rubber hose, so I need to improvise with a double nipple adapter.
The solution is ICT Billet 1/4" to 3/16" hose coupler. I also have another double nipple made of Stainless Steel with the same size, but in the end, I decided to use this Billet Aluminum version because it is lighter so it won't burden the rubber hose with it's weight:
I also purchase 2 different hoses for this purposes:
I connect the smaller rubber hose directly to the nipple on top of the modified Brembo Billet Rear MC and tie lock it for extra secure:
Then use the ICT billet double nipple to connect with the larger normal rubber hose to the Ducati by Rizoma brake reservoir:
Then I connect the normal size rubber hose to the Ducati by Rizoma brake reservoir:
Continue below:
