Doing some test fit of the exhaust assembly today and make sure all the hardware (bolts, nuts, bushing, bracket, springs, O2 sensor adapter and blanking plug etc. is complete).
First test assembly:
Then I realize, there is 2 anti-seize package, and decide to compare to my regular favorite Loctite Silver Grade anti-seize,
and from further research found Loctite had a NICKEL anti-seize which have a much higher heat resistant property up to 1315 Celsius or 2400 Faranheit, so I bought it from Amazon today and will arrive Monday.
But this also means, my plan to install the manifold and exhaust piping this Sunday will have to be delayed until after the Loctite Nickel Anti-Seize arrived on Monday.
Permatex also made similar Nickel Anti-Seize but I just like Loctite by Henkel better (just brand preferences).
Loctite 77164 Nickel Anti-Seize, 16 oz., 1 lb. Can: Amazon.com: Industrial & Scientific
Then I decided to test fit and make sure I can still install the AELLA Tie-Down Bracket with the SC-Project Silencer Bracket and will not hit the exhaust pipe. Oh, for testing, I used my spare RED color AELLA Tie-Down Bracket, but I will use the GOLD color one for the real install:
The right side barely clear the pipe and the left side had more clearance, but they fit, and this also means, I don't have to buy or thinking of new different tie down bracket and I don't have to buy longer ProTi bolts, which is good news to save money
Of course there are some bolts related to this SC-Project WSBK exhaust that will be replaced with ProTi bolts/nut or hopefully if I can make it fit, the Motocorse bolts for silencer, that is on the way from Motocorse JAPAN
That is all the update for today... I will have little update tomorrow but maybe not much since I am also planning to work on my car a bit tomorrow...
