An 1199S Project
Wow, please share more details, I (and I am sure many others) would like to learn about this more (y)
First time Carbon Fibre wet lay up.
I have made a few little parts out of CF previously. These parts were all out of sheet CF where I just had to cut the sheet to shape. So far I have made a registration plate holder, a small bracket for a brake line, a small cover plate, modified an old horn and lightened it using CF, made a brake stay and made a light bracket to hold the horn on the 1199.
There is a fibreglass part which sits in front of the rear wheel on my 45 year old Ducati. It is essentially a mudguard. I decided that I would try to make one of these out of CF. I purchased some Twill CF cloth about 1 metre square. It is about 1 mm thick. It is 200 GSM (grams per metre). From the same supplier, 1 litre of resin and about 300 mls of "Slow hardner". You also need to purchase a release agent which is basically a wax like product. I also purchased a grooved roller which is good for flattening down the cf cloth. You can see the tool in one of the photos in my first post about this. It is next to the cloth and has a thick wire handle.
My intention was to use the original fibreglass part as a mould for the new CF part.
Step 1. Prepare the area you are going to work. Clean and dust free and ensure your mould is on a stable surface and does not move. It needs to be stable so as you press down the CF cloth you are not moving the mould around.
Step 2. Apply the release agent to the mould. You use a sponge or cloth to spread on the wax to the mould and then polish. The instructions were at least 5 coats with the last coat you wait 24 hrs before using. I assume this builds up the wax thickness in stages.
Step 3. Precut your cloth to about the correct shape you need to cover the area. You need some excess to make sure you do not miss anything and you can cut to shape later once cured.
Step 4. Mix the hardner and resin. My products were mixed at 1 part hardner to 3 parts Resin. I mixed 50 mls hardner with 150 mls resin. This ended up being too much for what I needed but I did not know that being the first time.
Step 5. Lay the cloth onto the mould and then apply the hardner/resin mix with a paintbrush or similar. The resin permeates the cloth making it wet. The mistake I made was to apply each layer of cloth too quickly as I did not know how long it took for the resin to start to cure. As it turned out I should have waited longer between adding the layers.
Step 6. Once I put all the layers down. I did 4 layers. I then used scissors to trim the excess from the edges where it went past the mould edges. This removed weight from the cloth and stopped it sagging and coming off the mould. I then left it to cure for 24 hours.
Step 7. Removing from the mould. At first it did not want to break free put prying up the edges slowly worked. Because I had already repaired and painted the OEM piece, I found that when I pulled out the CF that it took some of the black paint with it. This did not worry me too much as I can repaint the OEM part. I rubbed and sanded the paint off the one side where it met the mould removing the paint. Today I added another cloth layer to the surface that faced the mould. This should give me a nice even finish on that side.
The next step will be to trim and perhaps fill any voids that have been created. Then a light sand and a final coat of clear over the top. On the old bike it will not be a part that will be seen very much but I want to make it look as good as possible. More pics to follow.
Love the build and the passion. 1199 is my favorite of all the group. Keep the updates coming.
Thanks for the kind words
That battery tray is to replace an old rubber one on my classic bevel SSD. I will have to add something to isolate vibration.
Here is a pic of a limited run of CF battery holder for the 1199. One of many parts to fit. Need to finish the SSD first.
New addition to the workshop
Optima bench drill and to go with it a very precise machinist vice
I have wanted one of these for years
I like this one as no changing belts to adjust drilling speed
Frame is back from the painter and looks better than I am sure they did back in the Ducati factory in 1978.
Ready to start putting bits on now. Here is the bare frame.
Safe riding and building till next time.
Time for a quick update. Here is a pic of some Titanium parts I had made for an older Ducati (1979). Three engine bolts, a swing arm spindle and two special centre stand bolts. From what I remember saving on weight was about 498g over the OEM steel parts.
I really enjoy taking weight off bikes
Still working on other bikes and a bit distracted with the restoration of my 1979 SSD Darmah. To add to my distraction is this new bike I imported from Japan to Australia. It is originally a 1984 model Ducati Mike Hailwood Replica MHR900. It has a few upgrades such as twin piston front calipers and Ohilins remote reservoir rear shocks. The fairing is a NCR replica and the fuel tank seat and tail is all one piece fibreglass NCR replica. This bike also has Keihan FCR 39mm flat slide carburettors, instead of the standard 40mm Delortos. It has been on display in a motorcycle shop for many years so I need to change fuel lines, bleed brakes etc.
Pic of the arrival home on the trailer.
