Its normal for a cold start RPM to be slightly higher. If you have the tool you can see the value the ECU is calling for as to idle speed. As long as that value and the actual idle speed are in sync I wouldn't worry.
But, I think you need to get a lot more miles and let the bike settle in to the new map before worrying about anything. There are a lot of adaptive values which learn and adjust. Get some miles on it. If it doesn't feel like it pulling that much put it into engine high. It makes the throttle feel much more direct.
