Welcome to the forum @Monsta , please keep us updated with your Streetfighter Build![]()
They are the same as far as satin finish and weave go I cannot comment on matte or gloss I only have satin parts which is what Ducati uses. Ilmberger is better built I think because they use a coating on the inside of the part though may be a bit heavier. Also some of ilmberger parts have a unique design not just copied from stock part. The headlight spoiler from ilmberger is larger and looks more aggressive.I noticed you sourced from both FullSix and Ilmberger. Are their matte color quite similar or slightly different? If different, what is the difference? Thanks
Some tail shots.
Forgot to add that is an integrated taillight with turn signals and brake lights. These are available for the panigale as well. I’d recommend the clear for visibility and safety sake. One of the vendors actually comes with plugs that work for Ducati already soldered V4evo maybe? I got the werkes that claimed plug and play. It was not I had to cut solder the plugs.
Those are very nice. I’m getting the silver ones returned and they will send another set.I am actually selling mine in Red Anodized color: Motocorse "SBK style" Ohlins forks caliper mounts for Ducati Panigale V4S and Ducati Streetfighter V4S in Red Anodized color. Motocorse Part#102130145
Some more photos of some of the carbon fiber I’ve installed.Forgot to add that is an integrated taillight with turn signals and brake lights. These are available for the panigale as well. I’d recommend the clear for visibility and safety sake. One of the vendors actually comes with plugs that work for Ducati already soldered V4evo maybe? I got the werkes that claimed plug and play. It was not I had to cut solder the plugs.
I have a bunch of matte CF stuff from Motocomposites (not recommended) and Fullsix (highly recommended). Both have less gloss than matte Ilmberger, which is more of a satin. Ducati calls the Ilmberger stuff they sell matte, but it is for sure satin. I re-clearcoated by Akra carbon fiber exhaust parts and DP heel guards with a 2K matte clear so it all matches.I noticed you sourced from both FullSix and Ilmberger. Are their matte color quite similar or slightly different? If different, what is the difference? Thanks
