The sub menus for each item is very similar. When you check for error codes, its if that particular module (ECU, BBS, Dash, Ohlins EC. etc.) have stored an error but its possible an error would appear in more than one place.I mean that you can find same activations in different menus. Also same error codes in different units. All linked somehow.
i read that but i assumed with updates it may have gotten better. thank you thoIt's not.
Read thread from ducati forum. It's long but full of info.
Multimedia system on V4???
How does the optional multimedia system work on the V4? How will it differ from the ScalaRider system I currently have in my helmet and connected,via BT, to my iPhone? Sent from my iPhone using Tapatalkducatiforum.com
Is there the possibility to assign the DMS module to the VIN number, as mine was tested on a Multistrada by the dealer before I fitted it to my bike. I would like to be able to allocate it to my VIN and activate the module in doing so.Ok. Just installed old battery back to test and verify activations.
There is also disabling possibility, so I disabled bluetooth, then logo was gone from bike display, then enabled again and bluetooth logo shows back.
View attachment 8157View attachment 8158View attachment 8159View attachment 8160
