I think I remember doing it when I changed the gear position sensor, the procedure looks familiar.You do need the dealer tool, DDS 3.0, Texa Navigator, OBDStar iScan Ducati, et al, to initiate the procedure. After that, it's as described in the b. link BMW Alpina posted.
Hi, so with the OBDStar I was able to set it into reset mode with the flashing C. I am running the procedure. Is it vital for the bike to be warmed up?You do need the dealer tool, DDS 3.0, Texa Navigator, OBDStar iScan Ducati, et al, to initiate the procedure. After that, it's as described in the b. link BMW Alpina posted.
Also, what is the configuration of the sensor? Does the RFID labeled side face the engine?Vital? I don't think so. If you have a problem you can always re-do it if you have the tool.
No.Does the RFID labeled side face the engine?
Could’ve sworn iv seen the high temp labled side on the outsideWould you have a picture by chance?
I'm sorry, I thought the RFID was on the same side as the high temp. Here is how mine is installed. Lettering is facing out.Could’ve sworn I've seen the high temp labled side on the outside
So I did the procedure the way it says and the gear sequence was all wrong ugh. What step am I missing that you mentioned above?That sounds right. Start in neutral, clutch lever then into first. IIRC, there should be some kind of indication on the dash that it recorded the gear correctly.
I had to do it quite a few times before it worked.
