2015 Diavel carbon white build.
Monsta
I got this bike in 2018 it had 902 miles on it. here’s some shots . I did some tire lettering and a carbon rear mudguard and carbon windscreen first thing. Also added ducati performance frame plugs and Ducabike caps and plugs for the oil and coolant. Carbon fiber exhaust heat shield.
Monsta
if you’ve owned a Diavel you know the brake reservoirs leak. I replaced them with motocorse, brembo Rcs new pads and discs. Titanium urethane Cush drives some titanium hardware. I still need titanium nuts for the sprocket carrier (This is before I heard about proti. ) pretty much every carbon fiber part made for this model I installed. The Ducabike ride height adjustment is a must I was dragging my termignoni exhaust when I pushed the bike on corners. It gives a 5cm lift, it’s adjustable so you can lower it to stock height. I stripped the AEM levers and put them on the RCS brembos. The brakes feel better on my Diavel than my Streetfighter now. (I’ll remedy that next winter )
Monsta
Some more shots. I replaced the belt cover with carbon fiber. I also swapped to an under tail plate holder with fullsix carbon surround plate holder. Carbon chain guard, and carbon frame covers. IMG_4506.jpegIMG_4503.jpegIMG_4509.jpegIMG_4507.jpegIMG_4508.jpegIMG_3756.jpegIMG_3753.jpegIMG_3750.jpegIMG_3752.jpegIMG_3748.jpeg
Monsta
Love the white and carbon contrast!
Good job.
Thanks man. Carbon fiber rims, Andreani cartridges for the front and a new triple lower and upper setup are the only things left I want to do. I just completed a bunch of other mods on the Diavel I’ll post about when I get some time.
