Motec at the moment, the marelli system is extremely complicated and difficult to work with. Yes tune individual cylinders then we just run two Lambda sensor when racing.
I've used Motec before so im familiar with it, i think it's a superior system to the marelli, SBU kit is well made, we modified parts of it like the ECU mount and the map sensor inside the airbox, theirs was just glued in position we mounted it mechanically. Otherwise very good system
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
