HI All,
I have started a small project with a 2023 V4SP2 and sourced a used Akrapovic under Engine system and have had a plug and play set of longer underseat end cans from SPF in the Uk made.
one question that i didn't check on is the difference between the Euro 4 and 5 bikes and the exhaust systems for them.
my hardware only has 2 Lambda ports and i see that the later versions use all 4 lambdas..
i have managed to source a 2023/4 euro 5 map for the undertseat system for my bike and will get this loaded up in the next week during service.
i guess ill see if i use Lambda plugs for 2 or have to modify the manifolds for the individual cylinder lambda fitment.
any experience on this issue would be greatly received
