Much of the original OEM switchgear and electrical sub-system parts, just needed a good clean and were in excellent condition after 12 years of use. Here's the LH switch gear.
Rear tail light, number plate light and indicator loom
Rear wheel speed sensor, this replaced cable driven (front wheel) speedometers, on earlier Monsters. Note that there is no similar sensor on the front wheel, as the 620ie had no ABS in 2003, therefore no phonic wheels on either front or rear wheels.
Clutch lever switch.
Ignition switch
Side stand switch. Earlier bikes such as this one relied on a circular contact switch, where a pin (shown below) engaged onto the side stand pivot to detect position. Later models use solid-state magnetic pick up switches instead.
Regulator, still serviceable after all these years and no corrosion.
Original Start/Stop/Run switch, in perfect condition
Oil pressure switch connector, prone to shorting and water ingress, this was later de-pinned and a rubber boot fitted over the connector to make it weather tight.
