I posted this in the other Ducati Forum but it’s being hacked so I’m reposting here.
The bike started as a V4 25 Anniversario 916…I have every original part bagged and stored properly because it’s a numbered bike.
I ride it abs will track it with race fairings on it for track days, so it’s a street bike that will do track days several times a year.
Evotech front axle sliders $41
Sicom Carbon Ceramic Rotors $4500
Puig Windscreen $95
Ducabike 4 Button Right Hand Switch Panel $285
Ducabike CPPI11 Left Hand Street Handle Bar Switch Panel $409
Ducabike KS03 Key Switch Elimination Harness Kit $123
Ducabike Line Cooler Kit $220
Superlite Titanium Lightweight Poly Cush Drives $180
Proti Titanium Rear Brake Caliper Bolt Kit $29
Proti Titanium Front Brake Caliper Bolt Kit $98
Proti Titanium Windshield Bolt Kit $37
Ducabike Gas Control Right Hand Switch Panel $300
Ducabike Kick Stand Bobbin Hook Extender $25
TWM Low Drag Half Lever for Brembo Corsa Corta $160
Stahlbus Quick Bleeder Valve with Dust Cap $40
Tygon 2375 Clear Brake Fluid Reservoir Hose 6mm and 8mm $10
Brembo Brake Master Cylidner Reservoir Mounting Kit $57
Brembo 17RCS Corsa Corta Brake Master Cylinder $372
4Evo Forged CF Winglets $540
Race Seats +20mm Embossed Seat with Carbon Fiber Base $319
Custom designed carbon front fender - Painted $550
Custom painted tank extender $900
R&G Tank Traction Grips 4 sets $150
BSD Side Stand Bypass $33
Domino A450 Road Race Grips $25
Ducati Wheel Service Tool Kit $195
FM Rear Linear Suspension Link $660
GB Racing Engine Cover Set $214
Melotti Racing Impact Absorber Billet Dash Cover $228
Spider Billet Brake / Clutch Lever Guard Set $208
WWB Ceramic Front Wheel Bearing Kit $175
Factory Pro Shift Kit With Ceramic Bearings $180
Rizoma Stealth Mirrors $425
New Rage Cycles Rage 360 turn signals $95
Spark "SBK Replica" Titanium Exhaust System $6600
Sprint Filter P08F1-85 Air Filter $240
Rizoma Wave Front Reservoir Kit with Brackets $255 (in box never installed)
Driven front 15T front sprocket $34
CNC Racing red flange nuts
$39
CNC Racing red sprocket nuts
$39
CNC Racing red sprocket holder $150
CNC Racing red axle nut set
$62
Aella black locking axle pins
$7
CNC Racing 520-43T rear sprocket for Ducati V4 $110
1.0 x Aella frame sliders for Ducati V4
$257
AEM black DSEI hub flange
$127
CNC Racing red inner taper cone
$32.25
Motool slacker V4
$147
Slacker V4 unit + case + a pack of 20 adhesive loops
EZ 3D 520 Gold chain
$170
Pierobon Extended Swingarm $7000
Motocorse billet rear shock mount $500
Brembro 13mm Billet Compact Race Rear Master with Integrated Reservoir (White Logo) - XA2C610 $1400
Brembro P2 rear brake caliper 34 mm pistons 84 mm bracket $500
Brembro GP4-MS front brake calipers $2600
Ferraro ZRAC brake pads $180
Frentubo clutch and brake lines w/ABS delete
28-29 mm clutch slave $125
H20 Radiator (no fan provision) $4100 for sale
H20 Radiator (with fan provision) $4200
Motorcorse Billet aluminum RH engine support $287
Motocorse Billet aluminum side frame plate $940
AEM Factory D-SEI billet lightweight hub flange $150
ATTACK PERFORMANCE rearsets $700
ThysenKrupp CF wheels $4000
FullSix CF rear subframe $5000 ish
Domino Quick turn throttle $300
H&M Quickshifter $600
IMA triple tree with 2 sets of bars $850
Probably $1500 in shipping costs and another $4000 in shop labor.
FKR 108 fork inserts $2000
TTX GP rear shock
Woolich tuning module.
Woodcraft clip ons handle bars
Puig Windscreen $95
$39
$39
$62
$7
$257
$127
$32.25
Motool slacker V4
$147
$170
TTX GP rear shock
